Old 05-04-2014, 05:08 PM
tonka.scout800a tonka.scout800a is offline
They are not all that difficult to work on, just did the one in my 149. It was a first for me. You can see what I did, thread sort of jumps all over the place with other issues.
http://www.onlycubcadets.net/forum/s...t=31416&page=2
Thanks for the link Sam. I am about to read through all that. I have my set screws soaking in wd-40 at the moment had to come in and verify the size of the allen screws, but here is what I found so far on my 102: looks like the sheetmetal collar is twisted off the set screws Also the throw out lever @ 10:00 in pic is on top of the thrust button.
SORRY FOR THE THREAD HI-JACK, Steved
Gotta start my own thread for this 102 and it's "problems"
Old 05-04-2014, 05:49 PM
You'll need a better penetrant than WD-40, I suggest KROIL or a 50/50 mix of acetone and ATF. {auto transmission fluid} ( even PB Blaster or Liquid Wrench is better than WD-40 )
The correct allen wrench size is 1/8". There should be TWO set screws in each of the three holes. Make sure you get all the crud out of the set screws and use a good, sharp edge allen wrench. If the end is slightly rounded, they can be ground flat on a grinder. Do not get it hot or you will remove the temper.
Since it looks like your arm is already off, if you take a hammer and "bump" the center button on the PTO, you can move the PTO to where the slots in the PTO pulley basket line up with the PTO.
Old 05-04-2014, 05:54 PM
OffTime's Avatar
OffTime OffTime is offline
I still haven't posted my pics of the fully caged ball thrust bearing that I have on mine in place of the release button. That takes care of the problem of it spinning all the time. I will try to post that soon, maybe in another thread.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-04-2014, 07:09 PM
Got it off pretty easy, WD-40 worked for me. Started my own thread. Thanks.
