Old 04-24-2014, 11:41 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Default 682/782 Sleeve Hitch Lift Bar
I have a lift bar the guy gave me when I bought my 782. I believe the bar is for a 682. My question is if I straighten the bend out of it, will it be the right length to work on my 782?
Does any one know the correct length of the 782 lift bar
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-24-2014, 12:16 PM
Travis,
That bar is a WF bar. Yes, if you straighten the bar out then it should work on your 782.
If someone doesn't get you the measurements I should be able to when I get home from work today.
Old 04-24-2014, 01:02 PM
Shrewcub's Avatar
Thanks, Mike! I just want to be sure it will work before I straighten it. I think it's NOS. It was zero wear on it: biggrin2: I don't want to screw up a perfectly good part.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-24-2014, 02:10 PM
I agree Travis. I will measure one when I get home and let you know.
Old 04-24-2014, 04:56 PM
I measured one off a 782 Travis and it was 26-1/8" long.
Need anything else let me know.
Old 04-24-2014, 05:09 PM
Shrewcub's Avatar
Mike, is that end to end, or hole to hole? This one is more like 27-1/4" end to end. It is 26-1/8" from the farthest part of each hole to hole, tho.
Each hole is 9/16" from the end of the bar.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-24-2014, 05:18 PM
jkier's Avatar
jkier jkier is offline
Found this a while ago
http://www.onlycubcadets.net/forum/showpost.php?p=138690&postcount=2
From this thread
http://www.onlycubcadets.net/forum/s...690#post138690
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 04-24-2014, 05:27 PM
Shrewcub's Avatar
Thanks, jkier!! Guess I will make one, unless someone has an extra
Any one need one for their 682?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-24-2014, 09:18 PM
Put in a trade post for what you want.
