Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 04-22-2014, 09:49 PM
vartz04 vartz04 is offline
Looks sweet
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 04-23-2014, 07:21 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Those look great!! I'd like to get a set on my zero turn and not have those stinking marks every time I turn. I'm not for sure on my size tires though. Great pics and great inspiration for me to do something about my problem.
The whole thing about a zero turn is that it's just capable of doing a zero turn. If you don't want tear marks you really need to make a 3 point turn. No matter what type of tire you use, if you have one tire turning and the other not turning, you will always get tear out.
http://youtu.be/L4i1CZIVm7I
Gary
Old 04-23-2014, 04:29 PM
What happens if you turn them like a dozer one forward and one in reverse?
Old 04-23-2014, 06:47 PM
gcbailey's Avatar
You can, that's what I usually do, but I think technically they still call that a 3 point, because if you just rotate like a dozer would, you'd be pointed right back in the same direction unless you moved over at least the deck width.
The key point is, you just can't have a wheel not rotating, if it's not spinning, it'll tear out the turf.
Gary
Old 04-23-2014, 09:14 PM
Thanks Gary. That makes sense. I don't always leave marks, just during the spring when the soil is moist. Maybe I will work on my technique.
Old 04-23-2014, 09:58 PM
Technique is a big part. The main reason I put on the ags, is due to very wet soil here when it is the rainy season and the ZT just seems to sink with the turf tires all packed with mud and will only spin making things worse. I needed to be able to make it thru the mud or be able to reverse and get out. I wasn't able to do that with the turfs. I have been learning the slight 3 point turn and it works great.
Old 04-24-2014, 01:43 AM
Lookin good DWayne!
