Old 04-09-2014, 07:01 PM
rugrat1965 rugrat1965 is offline
Default 1250 Issue
Hey guys. Just wondering if anyone might have some ideas on where to start. Runs Like a champ till it gets warmed up. Then, it idles fine but spits and sputters when I turn up the juice. Turn down the juice and it idles like a charm. Back and forth. Let it cool down and the same result. Runs fine till it warms up, then only runs well at idle. Rebuilt carb a year ago. New plug and also new coil. Thanks!
Old 04-09-2014, 08:29 PM
gmbadgley gmbadgley is offline
Try loosening the gas cap, I have seen vents get plugged and a vacuum is created in the tank starving the fuel system. It is rare, but does happen.
Also check valve clearance if it is too tight as the engine warms up the valves
could be held open slightly.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 04-09-2014, 08:40 PM
Thanks bud. I'll give it a shot tomorrow.
