Old 03-23-2014, 04:26 PM
gmbadgley gmbadgley is offline
Default I think I found the reason for slow crank
My 1450 has never had a real fast cranking motor and I always figured that when I had time I would check it out. Today I finally started.
Took a look at the wimpy corroded ground, made up a REAL ground cable out of 2 ga. welding cable and replaced it.
Made a real battery cable out of 2 ga. welding cable from the battery to the solenoid.
Funny thing, it really didn't make any difference. Then I checked the connection at the starter & cleaned that. No difference.
Ended up pulling the starter and this is what I found. I suspect someone smacked it with a hammer. I think I have a new one at the shop.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 03-23-2014, 04:35 PM
Yaaaa
Got the good out of that one!
Old 03-23-2014, 04:57 PM
gt383mag's Avatar
gt383mag gt383mag is offline
i believe my 1650 starter has a sticker on it that says "do not strike with hammer permanent damage will result" or something like that
Old 03-25-2014, 10:50 AM
My 800 starter has a warning label about DO NOT STRIKE!
Only thing better than having a Cub Cadet is USING one
Old 03-25-2014, 08:38 PM
I bought her last year and only had enough time to get running before mowing. I finally had time last weekend to start checking things out. It always cranked slow, I was hoping it was a connection issue.
I need to pull one of the decks apart and do the bearings next. But for $300 I expect to do some work on it.
Greg
