Old 02-04-2014, 08:17 PM
thadscub's Avatar
thadscub thadscub is offline
Default Wiring a cigar lighter on Cub Cadet 122
hi guys how does the wire for the cigar lighter hookup need a wiring diagram for it
thanks thad
Old 02-04-2014, 10:07 PM
Run a 14GA wire from the positive battery post to the lighter WITH a 15A inline fuse. The case of the lighter touching the pedestal should provide the ground.
Old 02-04-2014, 10:14 PM
TIMCRUTCHER TIMCRUTCHER is offline
Left my 1782 eom. Just put a BIC in my pocket.
Old 02-04-2014, 11:44 PM
thadscub's Avatar
will be using it for a revolving light for plowing snow
Old 02-05-2014, 07:20 AM
If you are going to go do that work, you might as well do it right.
Need:
* 14GA Wire
* Crimp terminal ends
* Toggle Switch SPST - 10A Rating
* Inline fuse holder
* 10A Fuse
Old 02-07-2014, 03:15 PM
jchristensen jchristensen is offline
Just did this on my 125. I ran the positive off of the accessory wire from the key switch. If you don't have that use one of the connections on the amp meter. Then I ran the ground to the frame. The dash is fiberglass so you have to run a ground.
Even if you don't smoke it's just cool to have it hooked up.
