Old 01-11-2014, 11:45 AM
cubs-n-bxrs's Avatar
Originally Posted by cubby View Post
fleet farm or farm and fleet will for shore if ones neer you or tractor supply, fastinall
I can tell you TSC and our local Fastenal do not have them. McMaster is the best place to get them. You can get a package of 25 shipped to your door for about what it costs to buy a couple at a cub dealer.
Old 02-19-2026, 03:51 PM
MUSKET MUSKET is offline
What size would i order from McMaster Carr and roughly what did it cost for 25? I have a 127 cub I'm working on mainly drive shaft also a 72 cub. The drive end that attaches to the engine on the is welded solid is that OK or should the whole drive shaft be replaced?
Old 02-19-2026, 04:14 PM
Farmall450's Avatar
Measure what you have and match it up to their catalog. They are standard sizes and light duty, regular, and HD. I assume the Cubs are regular.
Old 02-20-2026, 10:02 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Look up Jeff in PA,our sponsor above, for new drivesahft and hub and he'll include the proper solid pin for the driveshaft which you'll need to insert after installing the cooling fan blade on the shaft. At the other end of driveshaft past the rag joint connection, there is a .250" x 1.75" heavy duty spirol pin which you can get from McMaster or sometimes fleabay.
Plow blade
#2 Cart
QA36 snowthower
Old 02-20-2026, 03:39 PM
Grandpa53 Grandpa53 is offline
Try searching for "coiled spring pin".
Old 02-21-2026, 11:59 AM
From my searching it looks like Grainger has them pretty reasonably priced when I get over there I plan on stopping in to see.
