Old 12-16-2013, 11:22 PM
cadzag72 cadzag72 is offline
Ok, not sure if your 1650's carb is set up the same way, but on my k301's the fuel going into the carb has to pass through a 90-degree bend. This spot likes to catch pieces of gunk and allow the engine to run, but just barely. It throws you off track, because the carb can look spotless when opened up. If your carb has that 90-degree inlet, check there. Who knows what you'll find! I found pieces of a fuel bowl gasket and a deteriorating gas cap (separate occasions.) good luck!
Ian
Old 12-17-2013, 11:25 AM
Cub109 Cub109 is offline
The leaking fuel bowel has been dealt with, the float needle was sticking. The issue I'm still having is that it idles fine but runs rough real rough as you throttle up and at full throttle. I wasn't able to work on it last night but will flush the tank and check the inlet 90 tonight depending on what time I get back from the work xmas party.
Old 04-06-2015, 08:28 AM
rfrank's Avatar
rfrank rfrank is offline
fwiw. I was adjusting my 1450 carb as it wouldn't do anything more than idle. Long story short and 4 hours later. My condensor wire had broken and at an idle was making contact but above idle the vibration was causing intermittent contact. changed the condenser hidden behind the coil and it runs great.
