Old 11-26-2013, 07:49 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
This is going to get ugly and fast. Every Cub owner has his favorite model. So I'll list the ones I like the best and it's just my 2 cents. so you other guys don't hate OK? The ones in red because the engines are hard to get parts for would not be at the top of my list unless they are in very good condition.
1572 Kubota D 600 diesel
1772 Kubota D 640 diesel
1872 Kohler Mag18
2072 Kohler M20
Cyclops
1782 Kubota D 640 diesel
1882 Kohler Mag18
2082 Kohler Mag20
2182 Kubota WG-600 gas
2084 Kohler CH20
2284 Kohler CH22 last of the best as far as I'm concerned.
I'm sure others will chime in with what they like. Most of pre 97 stuff is pretty good. After that some good some not so much. Holler with what you find and we will do our best to help.
I agree with you 100% The only thing I don't like about the cyclops is the plastic. Once my 2072 is a smokin, I'll be a happy camper! Oh my 1864 ain't bad either, when you need a little better turning radius
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-26-2013, 08:09 PM
Think this one is in your area.
http://madison.craigslist.org/grd/4153514630.html
Old 11-26-2013, 08:33 PM
fourinchdragslicks fourinchdragslicks is offline
I like all af the IH cubs, but for something easier to work on, I would lean toward wide frames (1x8, 1x9. Quietline) or a spread frame (x82) The tunnel cover comes off easily, and allows you to make adjustments to the hydro, change the fan (if needed) lots of little things. If you come across a quietline, make sure you check iso mounts, and factor their replacement cost into a purchase decision. I line the queitlines, but replacing the isos will cost you around $120 using the correct rubber iso mounts from cub cadet (they cost about the same everywhere else I looked.) This forum is a wealth of information, and everyone on here loves to offer their information. Welcom to OCC!
Old 11-26-2013, 08:46 PM
Riverhen Riverhen is offline
What do you think of these?
http://madison.craigslist.org/grd/4198791883.html
http://madison.craigslist.org/grd/4161320666.html
I like the 1811 and was thinking about stop by after work tomorrow if possible to take a look. Would $1500 cash be a low ball offer?
Old 11-26-2013, 08:56 PM
snow blowers/throwers are rock chuckers. A blade is probably the most useful.
Also, the 129 sounds like a more reasonable deal. The other two seem pretty high to me, but maybe that is right in your area?
Old 11-26-2013, 09:04 PM
Set the skids ( shoes ) up a couple inches and it's not a problem on gravel driveways.
Old 11-26-2013, 09:05 PM
I have solid motor mounts with bolts for sale for $40 shipped. NF and WF are solid mounted from the factory.
Old 11-26-2013, 10:38 PM
The 1250 is what's known as a QL, Quiet Line and those are good tractors but most times need the ISO mounts repaired if they are original. Price around here is a little high, but not the worst. All depends on overall condition.
The 1811 would have everything you would need, thrower, blade and deck, but not a "good" price to me. It does have the hydraulic lift which is nice.
I hate saying something is to expensive, or a good deal because it's not my money. But for price, it all depends on if he's a motivated seller, and your in the "have to have" mode and "need" a tractor.
I don't think $1500 is a low ball price, heck if it's what you want, and everything looks good upon inspection, start low, you can always come up, you can never go down.
As you know, money talks, bull stuff walks. Show up with Franklin hand.
Good luck.
Old 11-26-2013, 11:07 PM
Welcome to OCC! Good luck on whatever you decide to do.
Old 11-27-2013, 06:57 AM
I like the 1811. If the hours are as low as he says they are it should be like new. I'd go with cash and see what kind of deal you can work out. It does have a lot of cool extras in the package.
Tags
kohler, ltx 1046, plow, thrower
