Old 11-08-2013, 12:41 PM
bocephus1991's Avatar
Default How much weight do you add?
How much weight do you guys add to push snow? I have AG tires and 73lbs per side on my 1211 . 42" blade pushing on concrete.
Brian
Old 11-08-2013, 01:16 PM
FlyingB FlyingB is offline
That weight is good but it would help more if you use turf tires with chains. Fluid in the tires is good also, it adds another couple hundred pounds.
Phil
A nice 1710 and QA42A snowblower.....and more to come .
Old 11-08-2013, 02:14 PM
My rears are loaded with liquid calcium. The tire, rim and fluid to together weigh 100lbs. Then, if needed I add the 75lbs wheel weights. But, I just added a cab to that tractor, so I'm going to make a run at it without the weights to try it. I think the cab weighs at least 100lbs.... maybe more. So to answer your question.... I add about 300lbs.
Old 11-08-2013, 02:24 PM
Hope you have tubes in those wheels if your running CaCl2 in them.
Old 11-08-2013, 03:34 PM
Yeah, I do. The calcium was free, otherwise I'd used something else.
Old 11-08-2013, 03:46 PM
You know, for conversational purposes though..... I've been in the AG industry for a long time and the newer tractor (90's and up) went to tubeless tires. When they add liquid cal to them they don't tube them. Never really saw any ill effects of it. I personally wouldn't do it..... but they do.
Old 11-08-2013, 04:08 PM
kostendorf's Avatar
I've got chains and 75# weights on turf tires with me at 210# in the seat. If I need more I've got cast iron body building weights I can add like the pullers use on the back lift. Adding any weight off the axles though will prematurely wear the axle bearings and promote leaks.
Old 11-08-2013, 04:46 PM
vartz04 vartz04 is offline
Do you have problems with the rear lift going up and down and the weight hitting anything?
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 11-08-2013, 04:48 PM
John
These were also tubeless and we also ran CaCl2 in the rear tires. I think that the way the rims are designed allows them to be filled to the point that the rim is submerged and maybe that's why they don't get rotted out as bad. Just a guess.
Old 11-08-2013, 05:28 PM
782CC 782CC is offline
for my son @ 80lbs. 350 to 400lbs total. Each wheel gets 50lb inside weights, 75lb outside, and fluid 50lbs??? Then have some weights to hang off the back if needed. 50 lb I think. Currently on AGs and chains but plan to get turfs for winter. Found more weight allows better control as to light and you will have to hit it sometimes to move harder snow. I could easily push more than he with less total weight and turfs with chains.
Oh, snowthrower on the front may tweak those numbers a bit. That was all on a blade setup. but I think it will be enough.
