Old 10-27-2013, 08:16 PM
IH_147's Avatar
IH_147 IH_147 is offline
Default Steering problems and I need opinions
Hi all,
On my 147, the steering is really tight when I turn left but when I turn right, all is good. Any suggestions? I've been thinking about investing in a nice deck for my 147. How do they mow?
Thanks all
Old 10-27-2013, 08:42 PM
Try checking your front spindle grease zerks.One may need some grease.Then there is the steering box,it may need a rebuild.I find the hardest part is removing the steering wheel but most times a air chisel works well to get it off.Don't forget to use the pb blaster....let it soak a few days if the steering wheel was missing the cap.
As for the decks,as long as you get one that needs no tlc,sharp blades help,it mows real nice.
Old 10-27-2013, 09:31 PM
All I mow with is a 147 and a 48" deck. Love it. The 14 HP will mow through anything I can throw at it. The cut looks great and leaves a great finish I'm proud of.
http://www.onlycubcadets.net/forum/s...ad.php?t=17959
Old 10-27-2013, 10:10 PM
IH_147's Avatar
do they cut good in thick grass thats kinda tall? and do they clog up
Old 10-27-2013, 10:54 PM
IH Cub Cadet IH Cub Cadet is offline
Not sure what to tell you on the steering as these IHCC's are still new to me, but I mowed all summer at a camp with a 126 & a 48 inch deck. I had heard the later 44 and 50 inch decks cut better. I've got a 109 with a 44 in deck, but thought the 48 inch deck did a better job.
However, the 48 inch deck can clog, but the biggest annoyance to me was tall grass catching and building up in the discharge side anti-scalp runner.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 10-28-2013, 12:46 AM
Originally Posted by IH_147 View Post
Hi all,
Someone else had this same problem a couple of weeks ago, their thread might be of some help.
http://www.onlycubcadets.net/forum/s...ad.php?t=27790
Old 10-28-2013, 02:00 PM
If your grass is dry and your mower deck is clean, no issues.
Old 10-28-2013, 04:05 PM
IH_147's Avatar
amd 14 horse will help it mow with more power and cut more
Old 10-28-2013, 08:41 PM
IH_147's Avatar
wil they mow this big stuff
Old 10-29-2013, 09:24 PM
dagenham dagenham is offline
I was the one with the problem. I just fixed it over the weekend.
Had to remove the steering wheel and column and replace the bearings and races.
