Old 09-11-2013, 10:04 AM
1450crum 1450crum is offline
Default Gotta do some real work to the 1450 now
I was reading a post about hydro fans and it got me to thinking.... I've had the tunnel cover off of my 1450 a dozen times of so since I've had it for a month and I didn't recall seeing a fan! Well sure enought one wasn't there. And upon closer inspection underneath I saw that the rag joint for the drive shaft has almost rubbed through the hydro filter. The tractor has new ISO mounts and grabbing the drive shaft, I can't feel any play in it. What could be the cause of the rubbing? I don't think I'll be using it much until I get a fan on it, I for sure don't want to burn the hydro.
Old 09-12-2013, 11:04 PM
rusmart rusmart is offline
Can you upload a picture?
On my 125, I vaguely remember seeing the driveshaft vibrate around quite a bit on the transmission side when it's running. It's been parked since I got it, haven't had enough time to monkey with it yet.
With your 1450 running, does the driveshaft wobble around? or is it straight as can be? Just wondering if by chance the driveshaft is bent.
I haven't goofed around with hydros that much, so I can't say anything from experience.
Russell
Cub Cadet Original w/ 3pt
Cub Cadet Original w/ fenders, creeper, & 3pt
Cub 100 w/ 3pt
Cub 125 w/ 3pt
NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller
Old 09-12-2013, 11:12 PM
All my tractors drive shafts run strait as an arrow from what I can see.
Old 09-12-2013, 11:43 PM
It's just a thought
Russell
Cub 100 w/ 3pt
Cub 125 w/ 3pt
Old 09-13-2013, 08:51 AM
May be kind of blurry. But yes the drive shaft does wobble a little in the middle of it.
Old 09-13-2013, 08:54 AM
Another pic. I know it greasy. Haven't got that far yet. Haha.
Old 09-13-2013, 09:01 AM
I need to weld up the trunnion anyway, I guess I'll fix it all at that time. I would like to know what all I need to order before I tear it apart.
Old 09-13-2013, 08:06 PM
Yes get a fan on that ASAP.
