Old 07-28-2013, 02:03 PM
ClickClickBoom ClickClickBoom is offline
Default K-341 governer / linkage setup
Is there any guide other than the engine manual that goes step by step how to configure the throttle cables/ springs as well as the governor. Had to dissassemble everything and now it's all funky.
I can only use about 1/4 of the throttle position on the tractor. It basically goes from nothing to wide open (and too fast) without using the full range of the throttle.
I also had to shorten the governer spring as it was about worn through. Might this be the cause of the issues?
not sure where to start, and when to attach the throttle cable to to the control bracket. At WOT or idle, ect.
1872 W/ Kwik Way loader
1650 W/ Dual Hydraulics, and rear lift
Cadplans Caddigger
qa36a blower, tiller, and snow blade
Gannon Earthcavator
Old 07-28-2013, 02:19 PM
No, there is no exact setting. The different holes are to make the governor more or less responsive. NO YOU CANNOT SHORTEN THE GOVERNOR SPRING!! You have to replace it!
Old 07-28-2013, 02:26 PM
I'm guessing that's my current issue.
I've got it adjusted so that it idles correctly, but when I throttle up the engine it get's to the top of the rev's when the linkage on the carb is only about a 1/3 open which is weird, I'd assume i'd die out from lack of fuel.
I also adjusted the governor linkage per the manual. held the linkage WOT, turned the shaft counter clockwise and tightened the adjusting nut.
Cadplans Caddigger
Gannon Earthcavator
Old 07-28-2013, 03:47 PM
k34 governer / linkage setup
Is this a typo and should be a K-341...??? Because, there is NO such K34 model.
Old 07-29-2013, 08:44 AM
yes, K341...
Cadplans Caddigger
Gannon Earthcavator
Old 08-02-2013, 07:58 AM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
I have a 14 horse doing the same thing. If you figure something out please let us know or shoot me a PM.
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 08-07-2013, 03:23 PM
sawdustdad's Avatar
Here's how my 1650 was set up. If it helps.
Old 08-07-2013, 03:38 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
the carb won't go wide open to run at 3600. it will as it accelerates then as you get to speed the governor backs off the throttle position of the carb to maintain 3600 . as the engine comes under load the throttle plate of the carb opens up. as that opens the air flow is increased . the vacuum created draws more fuel.
you don't need much air and fuel to maintain a set 3600 and that's how a governor works.
or maybe I don't understand the problem
