Old 06-01-2013, 08:10 AM
jimbob200521's Avatar
Default I may be picking up a Cadet 102 today, what to look for? *Now with pics*
Well I found a cub cadet 102 on Craigslist and can get it for $200. It comes with a deck and that's about it. the only issues are a brake that needs adjusting because it doesn't engage when you push the clutch and loose steering. other than that, I'm told it starts good and doesn't smoke. is there anything I should keep an eye out for, this machine is an hour away and I'd hate to waste a trip, any advice is appreciated, thanks!
Old 06-01-2013, 09:46 AM
johncub7172's Avatar
Thumbs up
Good luck! Hope you get the 102. Normally, the drive line components would need repaired and replaced. Things like the steering components would need repaired and replaced. But that's not to say this 102 will need all those. Best advice can be had by a test run of the tractor and visual inspection.
A 102 is a very good garden tractor! Any part it may need can be found with in the OCC Sponsors, and the many for sale threads at reasonable costs. With this in mind, you can have this 102 in tip-top shape!
Old 06-01-2013, 09:57 AM
vartz04 vartz04 is offline
Where are you in IL. I just posted up a 100 in awesome shape I found on Craigslist for $225. It has headlights and tail light as well as a 3 point rear lift. Doesn't have a deck but they can be found fairly easily.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 06-01-2013, 10:29 AM
I'm in NW Illinois, sterling to be exact. where are you located? For that machine, I'd be up for a little drive to get my hands on her :-P
Old 06-01-2013, 10:56 AM
I got a few pictures of the machine in question, seems as though she's had a 2nd hand paint job Anyway, the guy assures me aside from the brake needing adjustment and loose steering, she's in tip top running shape.
Uploaded with ImageShack.us[/IMG]
Old 06-01-2013, 11:06 AM
The 102 doesn't look bad at all. May not be a bad deal. Looks like a front blade is on it. Has rear ags also Good luck and hope you're able to get it!
Old 06-01-2013, 11:07 AM
He said there's no blade with it and the rear tires are going to come off and be replaced with turf tires so bear that in mind, no chains or ag tires :-(
Old 06-01-2013, 11:09 AM
http://chicago.craigslist.org/wcl/atq/3831951643.html
Old 06-01-2013, 11:23 AM
There we go, finally got the link to work and found the posting, thanks again! I emailed the guy so we'll see what happens.
Old 06-01-2013, 01:08 PM
I'd take the 100 over that 102 any day
