Old 05-12-2013, 08:54 AM
Dane in PA Dane in PA is offline
Originally Posted by cubby102 View Post
What about making a bracket to fit the tank between the grille and engine. Them make a exhaust to clear the hood. Maybe a stack since it is a diesel after all
I want to keep that space open, just in case I want to add hydraulics or something later. I was thinking of putting it on the side of the dash, tucked underneath the battery box...
Old 05-12-2013, 01:39 PM
cubby102's Avatar
cubby102 cubby102 is offline
that would work to, being a diesel a huge tank isnt really needed. im just not a big fan of cutting on this old metal dented up and rusty or not!
Old 05-12-2013, 01:54 PM
You could put a fuel tank under the seat.
Old 05-12-2013, 02:09 PM
That's an idea... An old plastic tank from a Sears Suburban might work... But I think I'll be adding fenders later... I don't know...
Old 05-12-2013, 02:21 PM
Who did the custom tank behind the seat last year? It turned out awesome.
Old 05-12-2013, 02:25 PM
I was thinking about getting a tank from these guys for my 71/121
http://www.boydwelding.com/
Old 05-12-2013, 02:28 PM
It would be cool if they could somehow make a dash-tower with a gas tank hidden inside...
The videos are uploading, and should be up in an hour or so.
And, remember the tank ain't gotta be very big!!
I spread fertilizer with my QL 1000 for over an hour on Friday, I burned about a quart of gasoline.
My QL 1000 only has a 1 gallon tank, that is good, because it uses so little gas, if the tank were much bigger, the gas might get stale before I used it!!
Old 05-12-2013, 02:29 PM
I have ran this engine for about 3 hours already, and the level hasn't changed. Oh yeah.
Old 05-12-2013, 02:34 PM
This is a tank off a Honda 13HP vert shaft engine. I had it mounted to the side of the tower for a while but have since moved it to the space between the battery and engine. One other option is to put the tank in the battery space and then go with a smaller dry cell battery like this one http://www.stealth316.com/2-dynabatt.htm#g16ep
These batterys have plenty of cranking power, used to have one in my race car with a 383 Chevy.
