Old 04-29-2013, 03:07 PM
Kinda off topic, but where are you located in Iowa?
Old 04-29-2013, 06:15 PM
Just a hint of gunk will do a lot of damage and cause a LOT of headaches in a fuel system.
Old 04-29-2013, 09:09 PM
jbreuer jbreuer is offline
In northwest Iowa, near Milford.
Old 04-30-2013, 08:04 AM
Sweet, I'm over by Cedar Rapids!
Old 04-30-2013, 08:20 AM
PaulS's Avatar
PaulS PaulS is offline
Welcome!! I agree with the others, you have a fuel flow problem. Follow what the others have suggested and the problem will show itself. It could be fuel tank, shutoff, plugged fuel line, or dirt in the carb itself. All these are not very hard to fix but seem to give headaches till found.
Old 04-30-2013, 12:13 PM
fordfan96 fordfan96 is offline
Default Quick Tank Cleaning
One way to clean the tank is to take it off and empty it, let it sit overnight cap off to evaporate out anything left, drop a length of small chain (like a dog leash, etc) into it and shake it around to knock any rust/scale loose. Then you can shake it out of the cap or use a small nozzle off a shop vac to clean it out. The chain is easier to get out and seems to clean better than a handful of nuts and bolts. You may still want to really clean and seal the tank, but this will work to get it going. I have two Originals, one is a 4 digit 1961 that was my dad's, and the other a 1963 that I got for parts but got running and use frequently to mow. They've been joined by a 122 and someday all will be restored. Someday.
Old 04-30-2013, 09:05 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Will be there in a couple weeks :-)
Think I can get an Original in carry-on baggage?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-30-2013, 10:22 PM
John
John,
I highly doubt one will fit in a carry on, BUT...no bother buying a ticket back to the south...I'll show you the tricks of the old tractor and point you in the direction you need to go...just pull your suitcase behind you. Might need to stop a few times for gas...Hy-Tran...probably a few times to blow the tires back up. See the sights, plan for a few months on getting back home ;-)
Tags
cco, k161, original
