Old 04-29-2013, 01:27 AM
Just my 2 cents but I would drill it a little deeper and tap it. Use a bottoming tap, then I would put a stud in with some JB weld, let it set. Then I would put a new gasket and a little silicone on both sides of the gasket and put the cover back on with a nut on the stud. That area is not a high stress area.
^^ That's good advice. I'm with Sam. Outside of tearing it down and getting it welded, it's the best option!
Old 04-29-2013, 07:22 AM
Fix or replace the rear. That's to nice of a tractor!
Old 04-29-2013, 07:36 AM
charlie105's Avatar
charlie105 charlie105 is offline
Thanks for the feedback. The plan is;fix now and maybe replace later. Still working on the details. This time i'm taking pictures !
Happy Trails !
Old 04-29-2013, 08:03 AM
cubby102's Avatar
cubby102 cubby102 is offline
I have a rear out of a 105 sitting here doing nothing but taking up space. If you could find a way of getting it there your more then welcome to it. It wouldn't be exact numbers but at least be the correct year range for it. But that is quite a distance
Old 04-30-2013, 08:04 AM
charlie105's Avatar
Default bolt torque 105 rear dif
Cubby 102;Thank you. If I could, I would. Just too far. Grrrrr. I was in the Buffalo area,and my wife was in Denver last week !!!
Old 04-30-2013, 08:09 AM
charlie105's Avatar
Is JB weld the best product to repair a cast iron bolt hole ? Does anybody here have better suggestions/experience ?
Old 05-05-2013, 09:06 AM
charlie105's Avatar
I stand corrected,it looks like my son may be coming through Illinois in August. I
don't know for sure yet. Is your generous offer still a possibility ?
Old 05-05-2013, 10:26 AM
macman81's Avatar
macman81 macman81 is offline
Yes jb weld will fix that. Been there done that. Just jb weld a stud in there and leave it. I have one holding my tiller on works fine.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
