Old 04-13-2013, 02:34 AM
Double check your ground as well. BTDT
Old 04-13-2013, 03:27 PM
sawdustdad's Avatar
Sounds like you need to check your hydro neutral setting
http://cubfaq.com/neutraladjust.html
X2. my 149 makes a similar noise starting. I need to adjust the neutral. It's on my list.
Does the tractor try to move in "neutral" either when shutting down or starting up? If so, that's likely the problem.
Old 04-13-2013, 06:38 PM
three4rd three4rd is offline
No...I have never experienced any problems with the tractor trying to go into neutral - quite the opposite - I have often had to tighten the shift lever to prevent it from going into forward or reverse when I don't want it to. I don't believe there are any issues with the transmission. I'm sure that last night I still had the brake locked when I tried to move the shift lever. At any rate, I had my repair guy come and take my tractor along today. He is going to try a used starter that he has (virtually impossible to get a new one anymore) and see if that's the problem. It's either that or something in the engine - although when it starts it sounds fine to me. Thanks for all the replies and suggestions. I just don't have the time to do much troubleshooting during the next few days and if it is the starter, there is nothing I can do about it. I'll be interested to find out what the problem is.
Best,
Keith
Old 04-13-2013, 11:13 PM
sawdustdad's Avatar
Best,
Keith
I think you misunderstood me. I didn't mean that the tractor tries to go INTO neutral, it tries to GO while in neutral, either forward or reverse, exactly as you've described. I think you need a neutral adjustment, not a starter.
One other item is the grass screen, if it's loose, it can make some noise rubbing the flywheel shroud. But that is unlikely to make it difficult to start, as an improperly adjusted neutral on the hydro does.
Old 04-14-2013, 07:58 PM
The thing is - I've had problems with the shift lever getting loose while the engine is running and wanting to move forward or backwards many times - it never once also created a problem with starting. Thanks for the suggestion though. I'll wait and see what my technician finds out. There is still the possibility that it's in the engine I suppose.
