Old 04-12-2013, 11:34 AM
Tim.E's Avatar
Tim.E Tim.E is offline
Default internal versus external brakes
I have a 100 transmission that has a couple of gears stripped. Is it possible to remove the reduction housing and internal brake set-up from this and put it on a 106 transmission to switch it from external to internal brakes?
Or maybe I could use both brake systems,internal on the left pedal and add a dual pedal on the right for left/right brakes?
Thanks for any input.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 04-12-2013, 11:52 AM
macman81's Avatar
macman81 macman81 is offline
as far as i know you can use either. i have a lot of wide frames and i've swapped internal brake rear ends for external brake rear ends several time with no modifications. the brake linkage rod should both hook up in the same spot if im right.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-12-2013, 12:33 PM
Yep, just did that on a 71, here is the thread
http://www.onlycubcadets.net/forum/s...t=20585&page=9
You will have to look through a couple pages to see the whole thing.
Old 04-12-2013, 03:32 PM
Tim.E's Avatar
Thank You for the input so far.
The main question I am asking is,can I put internal brakes on a 106 transmission (that has external brakes) by using the internal brake set-up from a 100 transmission.Will the reduction housing and internal brake parts from the 100 bolt on to the 106 transmission? What does the wet brake disc attach to?. I have never had one apart,so I don't know. The thing is,I like internal brakes better than external,and I would like to know if I can adapt my 106 and/or 128 to internal brakes.
Thanks,Tim.
