For the life of me I can't get the screws off the footplates. I was hoping to have the fenders off by the end of the day but it fought me all day those screws. I got two off by chiseling them loose. I guess it works but a few are being stubborn.
If you have a welder you can weld some nuts on top of the screws. Use a 5/8 nut and weld thru the center of the nut. I did that and it worked out.
Grind them off, or as previous said weld a nut on
To much to list! |
Then, where do you get bolts to replace them. I can't seem to find them anywhere.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
They are called Truss Head screws. Try Fastenal.
Myron B East Texas Most of of the fleet: Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with. |
a little heat does alot. just heat them up alittle and they should came right out.
I have been successful using a VERY large screwdriver and a crescent wrench on the screwdriver's square shaft to turn the screws out. PB blaster helps, too, I think. A firm rap with a hammer on the end of the screwdriver might help break them loose, too.
I have used a manual impact driver before with success also.
I use PB blaster and my dewalt impact driver with an impact bit.
I have been able to grab them with ViseGrips. Either they come out, or the head shears.
If the head shears, then you can get a better grip on the remaining bolt once the pan is out of the way. JMHMethod.
