Old 03-01-2013, 10:51 PM
JayJay JayJay is offline
Default Now you're ready!
After your response to my post, I thought, "He's going to the drill bit." I'm glad you got it out. Look at this way: now you have a story to tell
Jeremiah
Old 03-01-2013, 11:16 PM
Jumper Jumper is offline
vartz04: You have a nasty stubborn problem with that pin . I have knocked out many of them without allot of effort with the use of a roll pin punch and PB Blaster, a good thing to look at is as one person alluded to of a broken pin and the shaft turned inside the collar. Try a pickle fork between trans housing and collar and give it a few taps and see if it moves a little. (I had big problems too until I went to roll pin punches)
Old 03-01-2013, 11:57 PM
If your going to use carbide remember the pins are hard, run the drill dry do not use oil (use air to clear the hole), let the drill bit cut and don't use pressure on the drill. If one breaks make sure all pieces of the broken drill are cleaned out before you drill again. Make sure you have 2 spares in case one breaks, you will need them in the future if you don't break them here.
Old 03-02-2013, 12:18 AM
Woo Hoo, glad to hear you got it out.
Old 03-02-2013, 11:57 AM
cmatthew's Avatar
cmatthew cmatthew is offline
just an fyi. if you have a left over points push rod. it works good for the pin in the front axle.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 03-02-2013, 01:52 PM
nice job yea they can be stubborn
Old 03-02-2013, 02:23 PM
Great new! Glad you got it out!
