Old 02-02-2013, 11:01 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
Default 682 IH diesel conversion
So I will be getting a 682 soon that has a blown engine and I just got a golf course mower with a kabota 3cly diesel. I was wondering if there were any major differences between the 782d and the 682 as far as the frame hood and side shields are concerned. Any other info on such a conversion would be appreciated. I will post pics as i get them.
Old 02-02-2013, 11:27 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Exact same frame and hoods though the bolt holes in the frame may be different.
Old 02-03-2013, 12:15 AM
cub123's Avatar
cub123 cub123 is offline
Yeah, they are pretty much the same. What size kubota do you have? Can't wait to see some pics
Old 02-03-2013, 12:27 PM
Mr.Goffena's Avatar
I could not find the tag on it but for the price it didn't matter. After gutting out the engine hydraulics and other usable parts I should be able to make the money back by sending the frame and whatnot to scrap. The engine is already in there backwards with the drivline hooked to the front pulley and a fan on the back above the flywheel.
Old 02-03-2013, 01:02 PM
I have a drawing of the drive shaft adapter that bolts to the pulley if you need it. Numbers for the engine should be on the injector pump.
Old 02-03-2013, 01:32 PM
Mr.Goffena's Avatar
Ty for the number location. I may use the driveshaft that's on the engine because it has Ujoints at each end. The only thing that is concerning me at this point is how the engine mounts to the frame.
Old 02-03-2013, 02:05 PM
This is a pic from the Cub parts site for a 1572,the parts should be the same for a 782D. Note that it only shows one of the engine mounts but there is a left and right mount listed in the parts call out.
Old 02-03-2013, 02:46 PM
TheSaturnV's Avatar
There are 4 main parts to the engine mount. Each side is made up of two pieces of steel, dampened by two rubber bushings per side.
Old 02-24-2013, 04:32 PM
Mr.Goffena's Avatar
I got the downer mower today. It is a Jacobson turfcart. It has a D950 kubota engine in it that purrs like a kitten.
Old 02-24-2013, 05:58 PM
