Old 01-21-2013, 09:45 AM
cubfixer's Avatar
cubfixer cubfixer is offline
Have you ever seen the infomercial about the aluminum rods that you can use a propane torch with and weld up aluminum? Can't remember the exact name of the product. On the infomercial it looks pretty good. I've looked at the material strength of this repair and it looks pretty good.
If a bigger bolt would fit, I'd go with the bigger bolt. If it won't fit , I'd use the repair the holes with aluminum rods and a torch.
John
Old 01-22-2013, 10:44 AM
BigB87's Avatar
BigB87 BigB87 is offline
well ican go with a bigger bolt...7/16 shank size its wat i can fit threw the transfer case holes, just gotta drill the trans out.
Brandon
CC models: 86, 1650, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1978 1650 Hydrostat w/44" mower & 42" IH push blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 01-26-2013, 07:37 AM
BigB87's Avatar
Well guys thanks for the help on the transfer case bolts, i drilled and tapped for bigger bolts which stopped the leaking
Brandon
Old 01-26-2013, 11:31 AM
Glad you got it fixed!
Old 01-26-2013, 01:24 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
good deal ..
Doug
Original , 100 , 125 , 582
Old 01-27-2013, 08:41 AM
BigB87's Avatar
im glad as well...a gallon of fluid a day was getting old fast. if they strip this time im done
Brandon
