Old 01-25-2013, 05:13 PM
Cjbdvm04 Cjbdvm04 is offline
Default PTO collar set screw sheared off!!
I'm in the process of a rebuild of my 127. I got the PTO off successfully and realized the bearing was very rough while rotating so I figured replacement was in order. I could see that someone had messed around with the bearing as the punch hole was all boogered up and oblong with burrs. The collar had the long set screw with lock nut. The locknut was very loose and came off with my fingers. I put the Allen key in the set screw and just barely applied pressure when the exposed portion of the set screw snapped off. The remaining portion has no remaining "hex" for the Allen to grab. Suggestions? Thanks.
Old 01-25-2013, 06:04 PM
sawdustdad's Avatar
I'd just drill it out. A gear puller will remove the collar from the shaft.
Old 01-25-2013, 08:07 PM
Old 01-26-2013, 06:57 PM
Thank for the help. My mechanic friend just ground through the collar at the point of the set screw and it came right off. Bearing was shot so I needed to order a new one with the collar anyway.
