Old 12-16-2012, 03:47 PM
Shaner Shaner is offline
Originally Posted by gcbailey View Post
it's a fine art, what can I say.... buy the glue by the gallon and submerge and stick, re-apply as necessary.
On a side note, welding is something I've always wanted to learn. I can make "chicken droppings" but I look at these guys who are true fabricators and welders and I'm just in total awe.
the best way to learn to weld, is go and get yourself a welder. either a Mig, stick or Tig and just run bead after bead after bead. try changing positions, left hand, right hand, left to right, right to left, long arc, short arc, speed up or slow down, drag the rod, make horseshoe motions or circles. youll be surprised by how fast you can pick up a technique that works for you, that will make a weld bead look like a pros. for a beginner a wire fed welder (MIG) is the best to learn on. then go to Stick, then Tig.
Old 12-16-2012, 04:35 PM
cmatthew's Avatar
cmatthew cmatthew is offline
century 110 MIG welder. someday when money aint so tight..... i will upgrade! the one i have now works for most welding that i do. if i need to weld thicker steel i will grind 45's (make it look like a chisel tip) on the ends of the steel to be welded and build it up flush.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 12-17-2012, 10:40 PM
driller driller is offline
Lincoln 225 weldanpower. 1960's vintage with Wisconsin motor Cub6:.
Old 12-19-2012, 06:18 AM
kbrothers kbrothers is offline
Default Welders
Lincon 110 volt Mig and just oicked up a Hobart Stickmate AC/DC at Tractor Supply to weld my FEL project Haven't used a stick in years but am getting better penetration with the hotter machine
Old 12-19-2012, 08:47 AM
toyman's Avatar
toyman toyman is offline
Researched and bought this HTP 110v welder. Welds way beyond what would be expected for a 110 welder. It hasn't let me down in about 10 years.
Original Member #54
Old 12-29-2012, 09:02 PM
inboardnut's Avatar
inboardnut inboardnut is offline
My old Solar gave up the ship a couple years ago.
Replaced it with a Miller 211 .
GREAT little welder!
Old 12-30-2012, 06:01 AM
nikster's Avatar
nikster nikster is offline
I bought a 90amp welder from harbor freight ( $99.00) & practiced on some junk angle iron, black pipe, & it's paid for itself in the 3 jobs that I had. It's no super duper welder but did the job. I don't ever foresee big welding jobs in my future so it'll do. Bottom line...............
If I can learn to do some simple welding & flow a respectable bead----then ANYONE can. I even did a simple welding job for a friend of mine on his cars tow hitch. I was more thrilled than he was.
NIK,
Old 12-30-2012, 08:43 AM
gcbailey's Avatar
gcbailey gcbailey is offline
there's a guy that goes to church with me who is a welder/fab for a living. He's done quite a few things for me. He's the kind that goes out and looks at implements and comes back in a couple days and it looks better than the factory one. Maybe one day... haha.
Gary
Old 12-30-2012, 05:30 PM
wawcub47 wawcub47 is offline
got an old deuce n a quarter Lincoln stick. use mostly 6011 or 6013 rods. im not a welder by trade, but i get by.
Old 01-01-2013, 12:24 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Miller 211 Autoset with the 115/230 switchable plug & the aluminum spool gun. Works awesome for whatever I need. Still learning how to use the spool gun correctly.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
