Since we picked up a front blade earlier this year I thought I should add some weight for plowing snow, if we get any. I looked around the shop and found some farmall front wheel weights. 1 pair from cub and another that fit a C, H, or M. I got them mounted today. The total weight is 128 lbs. The extra weight sure makes the tractor feel different. I'm now looking at a couple options for chains. Do you think this will be enough weight?
CC 1450, 44A deck, #2 tiller, 42" plow/blade CC 124 CC 1220 #2 Cart |
Have you added fluid to your tires yet? What's your drive way made of? You might need to add some chains as well.
Nice weights! They look good on your 1450!
No fluid in the tires. There is still some room for some 10 in. dia weights underneath these if I need them. The drive is mostly crushed gravel, but we have a concrete pad in front of the shop that will need plowing also.
ACecil. And since they are IH brand weights they will work better than some off brand weights.
yep chains is always needed. some get by with out them. my 582 does good with out chains but when I put a set on it'll push 2' to 3' of fresh snow like its not even there.
with out them I need to ram it till the tractor stops then back up and hit it again. but I only had 40lbs in each wheel 2 years ago and got no snow last year. this year is the test (if there is snow) 95lb in each wheel , going to try with out chains first. I have 75lb JD weights in the 882's wheels pushing a thrower. I shouldnt need chains for that. but have a set just in case.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Put some fluid in the tires. Loaded tires make a huge difference in how the tractor handles!!! Washer fluid is a cheap way to go. I have washer fluid in a couple of my tractors, BIG difference!!!
Well, since my cub has NO weight other than the driver, I'm going to say a whole heck of a lot better than mine!
I have a blacktop driveway about 500 feet long-there is some incline to it.
I have fluid in my 108 cadet tires, and a set of weights. I am afriad to put the chains on because I hear chains will ruin blactop
![]() ![]() Cub Cadet 108, IH snowthrower, IH ?? mower deck Cub Cadet 1650, IH 44 mower deck, IH snowthrower 1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake 1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow 1953 Ford Jubilee tractor and F100 Pickup
I would prefer adding more weights rather than adding liquid. as far as chains go I've been looking at these.
http://www.millertire.com/products/t...2-tire-chains/ http://www.superior-tech.com/terragrips_01.php
