Old 11-24-2012, 03:00 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Default New Cub Accessories!
I recently bought a Creeper Gear and a Hydraulic Lift as well as a 3 pt. Hitch for my 104! I haven't had time to install them yet, but certainly not looking forward to taking the drive shaft out of it again.... Can be a pain in the butt! Just thought I would Post some Pics, because I know you all like pictures!
Does Anyone know where to get 10W oil for the Hydro-Unit or what Oil do you use?
Hydro-Unit:
3 Point Hitch:
Creeper Gear:
- Cory Sanderson
Old 11-24-2012, 04:57 PM
stroked350 stroked350 is offline
Good find.
Old 11-24-2012, 05:20 PM
Very nice! You can use Hy-Tran in the hydraulic lift.
Old 11-24-2012, 05:56 PM
ihcc104's Avatar
Thanks Guys!
- Cory Sanderson
Old 11-24-2012, 06:07 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Awesome find! That will be super nice to have on your 104
Don Smith
Old 11-24-2012, 07:07 PM
[QUOTE=ihcc104;161122] I haven't had time to install them yet, but certainly not looking forward to taking the drive shaft out of it again.... Can be a pain in the butt!
Cory
Nice stuff
take a look at this drive shaft coupler from Mid West Super Cubs.
"3” Long Driveshaft Coupler -Hardened Steel (Change top pinionwithout removing driveshaft)"
I bought one for that 71 I'm working because I can't move the engine forward when doing clutch work.
Old 11-24-2012, 07:18 PM
Nice score on the goodies!
Old 11-24-2012, 07:21 PM
ihcc104's Avatar
[QUOTE=Sam Mac;161177]
Cory
Nice stuff
Thanks for the info. So this would replace the coupler in the back by the Tranny? How does this eliminate taking out the drive shaft? My biggest issue is driving those spirol pins through the drive shaft... I guess I need to buy a special punch to do it easier.
- Cory Sanderson
Old 11-24-2012, 08:02 PM
Cory
With my 71 because I have a Mag12 in it with the deep sump I have to move the drive shaft to the rear to remove the engine. I can't just move the engine forward, it has to come straight up. This setup gives you more room to work with. In your case it may not be worth it, just thought I'd toss it out for you to think about. I have a grade 8 bolt in the front hole rather than the spirol pin.
Old 11-24-2012, 08:33 PM
ihcc104's Avatar
Awesome, thanks. I just checked out their site and they have a lot of stuff. Thanks for sharing. So grade 8 bolts have the same shear strength as spirol pins?
- Cory Sanderson
