Old 09-26-2012, 02:19 PM
no74falcon's Avatar
no74falcon no74falcon is offline
Some "before" and "after" photos of the weights. I used a cup brush and cleaned them up, primed and painted them. The black pieces on the "before" photo are some wheel protectors I cut out of an old innertube. I am going to try some adhesive to hold them in place while I mount them, and let you know in the Spring (or sooner ) how they worked out.
Old 09-26-2012, 02:49 PM
Your weights came out great!
Old 09-26-2012, 05:08 PM
FYI, unless your rims have a really narrow offset, those weights will touch all the way around the outside of the rim, and those rubber pieces will do nothing.
Old 09-26-2012, 05:27 PM
no74falcon's Avatar
Thanks Matt! I appreciate the thought and will double check where they sit in the wheel. Might need to rethink I guess...
Old 09-26-2012, 07:26 PM
no74falcon's Avatar
Matt G suggested I rethink where the weight might make contact with the wheel. I looked again and he was absolutely right, I would have had the rubber pieces in the wrong spot. I ended up cutting 4 bigger pieces of the tube about 2" wide, enough to go all the way around the weight (sans where the notch is for the valve stem), put one on the bottom of the wheel, carefully put the weight in and then left the nuts loose on the bolts. I then slowly rotated the wheel and worked the the remaining pieces in place, and adjusted all 4 pieces to where they weren't visible, and tightened down the nuts. The pieces of innertube tightened down nicely and hopefully will work as an insulator the protect the wheels. The other weight is ready to look like the first.
Old 10-22-2012, 08:01 PM
no74falcon's Avatar
Just wanted to give an update... I finally got the parts needed to complete my install on the blower and it seems to work ok. Now for a complete teardown and make sure everything is put together properly.
