Old 07-08-2012, 05:04 PM
Vince_o Vince_o is offline
Default So I took the tin off
So I took the tin off as Paul showed up and found a 16 HP in it !!!!!!!!!!!!! So now what do I do with it?
Anyone know if I can solid mount this to an 82 plate and put it in a 582 frame?
Old 07-08-2012, 05:20 PM
dclinansmith dclinansmith is offline
Vince, I am not familiar with a 582 but if it uses the same frame as the 682 & 782 you should be able to install a single cyl K series engine. The frame is built to accept the flat mount or the wide frame type. I put a 12hp in a 682 using a modified wide frame mount. It was a bolt in with no modifications to frame or engine mount. The driveshaft even fits, I don't remember having to change anything just plug it in and go.
Old 07-08-2012, 05:34 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Sweeet deal there! Post up on how it fits in the 582 when you get that far.
Old 07-08-2012, 06:17 PM
Darrell Darrell is offline
Vince , A 1282 has the single cylinder , but i am pretty sure they used some risers on the steel plate. I think MattG installed a single cylinder in his loader tractor , might look at his site.
Old 07-08-2012, 07:14 PM
Vince you lucky dog!!!!I am sure you will fit that baby in a 582.
Old 07-08-2012, 09:38 PM
You'll need the 1210/1211/1204/1282 etc. risers but they can be used with the QL rails.
Old 07-09-2012, 07:58 AM
I will be watching this Vince!
I plan on doing the same thing to one of mine!
Old 07-10-2012, 07:24 AM
Crazy
After talking with Matt and a few other guys, Ive decided to go a differant route with this eng.
Old 07-10-2012, 07:36 AM
What you up to Vince?!
Old 07-10-2012, 02:21 PM
I tell you but with what I do with it will pay for piston and rings for a mag and a command that stitting on the self.
