Old 07-06-2012, 08:23 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default 982 Fuel Issues
Well, after several stalls and cleaning out the carburetor, I finally broke down and removed the gas tank and lookie lookie what I found.
First I must say that before I ever started the M18 that I put in the tractor, I had drained and replaced all of the fuel lines, removed the float/bowl assembly, cleaned it, and I added seafoam and startron to the gas that I put in to run through the engine........well, two times this thing stalled on me and I removed the bowl and cleaned it out again.......the fuel filter was not catching all of the crap....BUT WHERE WAS IT COMING FROM ???
So, not wanting to go through this breakdown experience again, I pulled everything apart and here is what it was...absolutely cruddy valve and the fuel filter had caught a little more this time but not enough. Also found some "other" debris in the tank from the previous owner.
Bought new valve, new tank valve bushing, new bowl gasket, "Massen-gilled" the tank REALLY good. Tomorrow, I am putting it all back together, flush all again etc.
Might be worth draining out your fuel tanks guys and check them out.
Joe
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 07-06-2012, 10:09 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Oh thats just some real pretty stuff there..the 107 I just bought was hard to start and would stall out when throttling up, so did the same thing and found pretty much the same thing. My glass bowl filter was over half full with dirt, grime and gunk, the po had no clue what he was doing with it. Pulled everything apart took the carb cleaner to the carb and put it all back together and now its smooth as glass..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
