Old 05-08-2012, 03:32 PM
cub71 cub71 is offline
Default throttle cable question
I just bought a 10HP kohler for my 71 and I am trying to get everything hooked up. I was wondering if I will need to get a shorter throttle cable than a 7HP throttle cable that I have?
Old 05-08-2012, 06:59 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Well.
You can always loop it longer, or you can shorten it (I'd use a dremel to cut the coiled sheath ... the inner wire is pretty soft though)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-08-2012, 07:50 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
you are going to have to shorten it the 7hp governor is in the front of the motor and the 10hp is on the side of the motor you can try to put a loop in it but it may not work properly due to binding.
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 05-10-2012, 08:19 AM
I used a dremel and cut the outside covering then cut the core to lenth. It didn't work half bad and saved me $$$
Old 05-10-2012, 08:22 AM
jbrewer's Avatar
I had done the exact thing the week before on my Original. That outside layer is tough stuff ... but not for a dremel cut off wheel .
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
