Old 04-25-2012, 11:14 PM
red56turbo's Avatar
Originally Posted by gardenpest View Post
Nice work......... but aren't the threads on the wrong end ?????
They look like bolts made for the rear lifts like on the later quietlines and 82 series. They used these bolts instead of the rod all the way through.
Josh
Diesel Cub Cadets...........
Old 04-25-2012, 11:31 PM
gardenpest's Avatar
gardenpest gardenpest is offline
yeah , I remember seeing a thread about that.....I guess those newer machines aren't something I'm familiar with..only frankenstien bolts I see are front attch. Gotta get with the times LOL
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
Old 04-25-2012, 11:38 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
send me a set, I'll be happy to test them for yah...
Doug
Original , 100 , 125 , 582
Old 04-26-2012, 05:20 AM
ajgross ajgross is offline
Inactive Member
Most people think that "Frankenstein Bolts" are the bolts for the QA on the front of the frame, but we are usually refering to the bolts for the rear lift.
AJ
Old 04-26-2012, 08:24 PM
I can make those front attachment bolts too.
I'd make them with a bolt, spacer and washer for a workable piece instead of machining a larger head bolt and chasing threads.
Old 04-26-2012, 08:44 PM
Sent you an email
Old 04-27-2012, 12:33 AM
gardenpest's Avatar
Thats a great idea, with time and wear if it gets a flat spot you can replace the spacer instead of the whole bolt . I made a bolt the other day myself...
I picked up a 42 inch deck that the po must have lost the spindle bolt for..
So i that how hard could it be , after looking at cost of new and shipping
I decided to give it a try....drilled a hole from thread end through head of bolt
I think it was a 3/16 but I'd have to check to be sure . Then drilled a bigger hole in the bolt head and tapped it for the zirk. Thank goodness for drill press's .
Old 04-28-2012, 05:42 AM
nikster's Avatar
nikster nikster is offline
Seems to be?
Nik
Old 04-28-2012, 05:57 AM
Did somebody say drill press!!??
Old 04-28-2012, 10:37 AM
clint clint is offline
I'm not trying to dog your work, just want to know... What materiel did you use to make the bolt ? Also the threads look shallow in the picture, but pictures can be misleading... or is that the normal thread depth ?
edit... (% thread)
