Old 04-22-2012, 09:45 PM
aarolar aarolar is offline
Default Just got home and already having issues
Well guys I just got my 124 home and pulled my aerator around the yard some with it and used both hi and low range on the creeper. I got ready to park it for the night and to back it under the shelter and had the bright idea to put it in low to give me more control backing the aerator but when I let out on the clutch it shut the tractor down. I tried again with the same result so I just put it back in hi and backed it up. When you shift it into lo there is no click for like shifting into hi it just flops back. Also there seems to be oil leaking from on top of the creeper somewhere but it was too dark to see. Any one got any ideas on what I am up against?
Old 04-23-2012, 11:03 AM
Donovan M.'s Avatar
take the creeper off and see if your roll pin is still there
Donovan:
62' Original-fenders
Old 04-23-2012, 11:21 AM
Can I remove the creeper from underneath or does it require taking the transaxle out of the frame?
Old 04-23-2012, 12:22 PM
I recommend splitting the tractor. I had a heck of a time trying to install my creeper in my 126. It would have went so much faster if I just pulled the tranny out of the tractor.
Old 04-23-2012, 09:21 PM
Now Im having more issues, the starter generator is overheating getting so hot the paint is peeling off the back of it and making a interment moaning type noise? Any ideas on what this could be...
Old 04-24-2012, 10:29 PM
Ok I got the S/G apart and the bushing in the end is completely gone, prob .020+ oversize. I have a kit ordered that comes with the bushing, bearing and brushes but I have a few more questions.
1. I am curious about the wick, where exactly is it located and where can I come up with a replacement, I am pretty sure lack of lubrication is what caused this failure and need to make sure it doesn't happen again.
2. I have read that I should turn the armature before reassembling, how much should I remove?
3. Anything else I need to know to keep from screwing this S/G up?
Old 04-24-2012, 10:57 PM
From my knowledge of generators, I would put a good synthetic grease in it at assembly, it will probably last as long as the original bushing. They did not have synthetics when they assembled that S/G.
You could use a candle wick.
The bare minimum to clean it up.
Gotta clean the groves on the armature, a hacksaw blade works great.
My local S/G shop does the rebuild so cheap, I would never open one up.
Old 04-24-2012, 11:06 PM
Thanks for the reply S/G shops are pretty non existent around my area and plus I figure if I am going to have a toy of this vintage I should at least know how to repair it when it fails.
Old 04-25-2012, 09:00 AM
I wouldn't turn the commutator unless it is really grooved,
and really no need to fool with undercutting the segments.
Just clean it up slightly, and replace the brushes if they are worn.
measure the armature shaft to see if it is undersize.
some rebuilders cut the shaft undersize and install a undersize bushing to compensate but it is a "custom" thing.
Old 04-25-2012, 09:43 AM
Im contemplating real hard on locating a needle bearing to subistute for th bushing. I am unsure of where in going to find a wick to properly setup the bushing. Does anyone know if they had oilite bronze in 69?
H
