Old 04-14-2012, 08:08 PM
I make brass PTO buttons, they are easy to replace and the brass one will lasty for years.
click for bigger picture
That's a picture of a K301 Kohler laying on it's side. See the "lump" on the bottom of the oil pan? That is one way to identify a 12 hp from a 10 hp Kohler ( 10 hp is flat )
Old 04-14-2012, 09:20 PM
cubby102's Avatar
cubby102 cubby102 is offline
I'm not sure if thiss is your problem but I know on my 102 it was down after a short period even after the Carb rebuild it would still do the same thing turned out it was my coil replaced it with onother one I had laying around and it hasn't done it since... Just a thought
Old 04-15-2012, 06:12 AM
nikster's Avatar
nikster nikster is offline
1st. things 1st.,
Ask alot of questions for the # 122. This way I won't have to since I have a # 122.
When I 1st got my # 122 it started dying on me after 10min., start right up again & kept on killing on me every minute or so? Start right up again. When the engine cooled off it would run for 10min., & the problem started up again.
Here's what I did for a quick fix for MY problem & it worked, knowing deep down inside I HAD to rebuild the carb.
I cleaned the bowl on the carb, disconected the fuel hose & shot some carb spray into it & cranked the engine for about 10sec., & did it again. I removed the gas tank & flushed it out & added 1 quart of new gas with some Sea Foam in it. Ran it dry & the motor NEVER stopped.
This was a temp., fix & it worked for about a month. Then it happened again.
I then ordered a re-build kit from my local NAPA store & rebuilt the carb. Never had that problem again. Now I NEVER re-built a carb in my life. I took my time & followed these instructions; http://mgonitzke.net16.net/tools/carb_rebuild.pdf
If I can do it so can you. Just take it slow & now its easy & well worth it.
Nik
Old 04-15-2012, 02:52 PM
fer100's Avatar
fer100 fer100 is offline
No one has responded to the serial numbers, Frame number 213703 Was made in Sept 1967 for a Cub Cadet 122 Kohler Model number and spec number
shows it the engine made in 1967, a K301, 12 hp. I take it that you saying frame you mean off the rearend. Which would be the correct location for a 122. Allso the hood should say 122 on it also.
,1 Ariens 934 Hydro with cyclone rake
