Old 01-15-2012, 11:21 PM
thejed72 thejed72 is offline
Default new to forum, what classic cub do I avoid?
I'm sure this will be a mixed bag answer just like asking which one is better/ more versatile. I've wanted a classic 60's-70's cub for a while to go along with my IH Scout II and my Travelall, and want to get an all around good little tractor for around the house stuff. Maybe light plow, garden stuff, and of course, mow. I want one that it's still affordable, dependable, parts are easy to come by, etc. Everyone has their own opinion to this, but what I'm really looking for, is what to stay away from.
Old 01-15-2012, 11:24 PM
Avoid those ones with 2 brake pedals and 26" rear tires.
(More for me that way!!)
ESPECIALLY the red ones that run on diesel!!
Old 01-15-2012, 11:41 PM
cub123's Avatar
cub123 cub123 is offline
I would keep away from the QLs, the models with the rubber engine mounts, 1250 etc.
Old 01-16-2012, 12:10 AM
Keep away from any cub that is coming head on at you, especially if you are on a JD machine!! The WF are often easier to work on due to the extra space and 12hp seem to be the most common. I see lots of 129's and the parts are easy to come by and somewhat affordable, except for the 3 point hitches if you are wanting to do tilling, etc.
Old 01-16-2012, 12:25 AM
72-149's Avatar
72-149 72-149 is offline
i agree with you those supers are junk !!!
Old 01-16-2012, 01:52 AM
Not just the QL's used ISO mounts. The 1572 used them as well.
http://www.cubcadet.com/webapp/wcs/s...A/040026900028
Old 01-16-2012, 02:02 AM
TheSaturnV's Avatar
Obviously you will want to keep away from post 1981 machines that were built by CCC rather than IH. The CCC tractors are plenty fine, but you want a proper companion for your Scout.
The next basic dividing line is the narrow vs wide frame models. In some areas of the country you will have better or worse luck in finding implements for the two styles of machines, which are not interchangeable. In the narrow frames, you could look for 127s or 147's made about 1971. In the wide frames, look for 129s or 149s.
Lots of other choices, this is just a basic set of ideas for you.
Old 01-16-2012, 06:33 AM
When you are looking at Cub Cadets and want a true IH made model, it ain't about the model year so much but rather by the serial number range. If IH made it, then the chassis serial number will be <699,999. CCC started building tractors with serial numbers 700,000>.
Old 01-16-2012, 07:45 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Since we're talking QLs, Vince, where are ya? :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-16-2012, 09:45 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
Im new to this . so tell me if Im wrong..
if its Red. make sure it has a cast iron rear end, for an IH built model
