Old 01-10-2011, 06:57 PM
Lonestarcub Lonestarcub is offline
Default Push button starter
Has anyone ever tried using this push button starter from Tractor Supply?
it looks like the same as the one sold for the Cubs and it calls for a 1 3/4"
hole opening which should fit.Just curious...it cost 12.99.
Thanks,Bruce
Old 01-10-2011, 09:36 PM
I'm sure it would work and be a good quality part but the button sticks out about twice as far past the dash as a factory one.
Old 01-10-2011, 09:43 PM
Sminkey
Guest
Posts: n/a
You could make a shim for it so it doesn't stick out so far. Good find!!
Old 01-10-2011, 10:09 PM
juniors1282's Avatar
Ive got one in my "O" it works just fine. It does stick out to far, but works just fine. Here's a picture so you can see what it looks like. Oh and it does use the same mounting holes.
1966 IH cub cadet 102x2
Old 01-10-2011, 11:20 PM
I had a 100, that had the longer push button starter. Never had a problem with it.
Old 01-11-2011, 04:39 AM
Monzaman78's Avatar
Monzaman78 Monzaman78 is offline
I also have the same button on my "O" it works great.
If You Aint Gettin Dirt In Your Beer You Aint Racin
Old 01-11-2011, 09:38 AM
I had that on my 100 that I restored. It worked great and was rated for 12V.
Old 01-11-2011, 11:03 PM
Capital idea! Simkey, I didn't think of that.
Old 01-21-2014, 07:57 PM
garnold's Avatar
garnold garnold is offline
Did you try shimming this out? What is the advantage of this, just not turning the key?
Old 01-21-2014, 08:02 PM
A few of the early Cubs had a separate starter switch, rather than the 3-position key switch. (Off-run-start)
Only thing better than having a Cub Cadet is USING one
