Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 09-02-2020, 10:01 AM
David Reinhardt David Reinhardt is offline
Default Bench testing stators
I’m looking for some help on testing a Briggs and Stratton charging system. I have read and understand the tractor (1440 & 1641) service manual and the Briggs manual. Preforming the test indicated the stators in both tractors are defective. I have a couple used spare stators but no way to test them. New unbranded ones are around $50 and OEM are $100 . There are plenty of used ones cheaper but are they good? My question is their any way of bench testing a stator? I'm trying to keep from pulling the engines multiple times.
Old 09-02-2020, 03:09 PM
Vrobert's Avatar
Vrobert Vrobert is offline
More than likely they can be measured with an ohmmeter. Should be low ohms between the two conductors and an open circuit from conductors to ground. Check a bad one first and compare to the questionable ones.
Maybe someone else has one they can measure or has experience with them.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 09-03-2020, 10:25 AM
mortten mortten is offline
On the bench you could only check for an open or a short. There wouldn’t be any way to check output without the other parts of the system in place and running.
Doug
QA-36A
42" blade
Old 09-03-2020, 06:35 PM
Thanks for the replies. I need to pull both engines maybe by examining the defectives ones against the spares I have for shorts/opens it will help.
