i ran into this issue with my 123 cub when i disassembled it. the threads in the block are badly corroded and some have completely rusted away. i cant get the elbow exhaust pipe to thread back in. what can i do to get this repaired? i dont want to scrap the block since it is original to the tractor but i also want to be able to use the stock and stack style exhausts i have. my local Case IH dealer said there wasnt any way to repair it other than to make it a boat anchor.
I think you can drill and tap the bosses to the sides of the exhaust outlet and put a flange on the pipe. I may be wrong. Sombody will either correct me or tell you the correct way to fix it.
thats what i was thinking too. but i was informed by the IH guys that there wasnt enough "meat" to retap the outlet. i had also come across an idea on haveing a bushing at the right diameter put in and tapped for the exhaust but that will be more than i can do since i am limited in tools
I think you are misunderstanding. He is suggesting that you drill and tap the bosses on either side of the exhaust port(hole). Some blocks are already done and this is were a bolt on manifold would mount. You would not be using the threads in the port(hole) at all.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
Ok yea i see what you guys mean there is plenty there to drill and tap the bosses. got a little confused there and not sure how i did that to myself. Thank you guys for the help! :biggrin2.gif:
Don't go and drill to deep. You need to find a spec on how deep to drill, or you might have more of a problem than you started with.
I can get a rough estimate off of my 12 hp unit from my 128. It was factory drilled.
11/16ths is the depth on mine.
Thanks for the measurement DX3! I knew it couldnt be too deep but wasnt sure how deep to go. Now i can use both exhaust styles and just undo a couple of bolts. Yall are invaluable sources of information!
Does anyone happen to know where i can get an exhaust flange to fit the K301? i dont have a band saw otherwise i could make my own easily instead of making my forearms look like popeye's. Also what kind of metal would be ideal for exhaust tubing?
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Thread Tools | |
Display Modes | |
