Old 07-27-2015, 05:23 PM
cubcadetguy123's Avatar
cubcadetguy123 cubcadetguy123 is offline
Default Flywheel ?
Ok guys, looking for a little bit of advice.
Just started the 73. now that its running, I am noticing that the flywheel-pulley on the front of the engine is bent. Could that bend the crank or crack something?
Old 07-27-2015, 06:03 PM
I may cause a vibration problem and chew up belts. I would suggest that you replace it.
Old 07-27-2015, 06:38 PM
But will it break the case or crank? There is no question that it needs replaced but I don't think I will have it done in time for a show around here if I get in to that. I need to get it on a trailer, off the trailer and back home.
Old 07-27-2015, 07:27 PM
I highly doubt it.
Old 07-27-2015, 10:05 PM
Thanks. One more thing, the pulley on the generator is slipping allot. When you try to start it will spin and catch after a few seconds. Can you get different pulley sizes or is it the belt?
Old 07-27-2015, 10:29 PM
seems like it is the belt,or the s/g basket pulley is slipping on its mounting thingy....
Old 07-28-2015, 10:43 AM
cadzag72 cadzag72 is offline
Yeah, you may have a bad belt or not enough tension on it.
Ian
Old 07-28-2015, 11:08 AM
ok. I probably have a bad belt because the belt is tight on the pulleys. The thing is that it sits really nice on the big pulley.
Old 07-28-2015, 12:19 PM
Ian
