Old 07-23-2015, 09:20 PM
Nice work,it should give you years of trouble free service.
Up to 530 and counting...
Old 07-23-2015, 09:39 PM
Originally Posted by tpelle View Post
I didn't take a pic of the solid motor mounts, but they are a direct replacement for the rubber iso mounts. I bought them from Jeff Derstine, who I located from this site. Work great - Thanks, Jeff.
That look great, glad I could help you out with parts.
Solid motor mounts with hardware
Old 08-03-2015, 09:43 AM
pdlloyd975 pdlloyd975 is offline
Impressive project! VERY nice... Cudos!
Patrick
75 & 76 Cub 1200's
44" decks & front blade
Original Service Manuals
Old 08-03-2015, 04:40 PM
I bought one of those batteries too. Great batt. for the $$.
Old 08-03-2015, 06:21 PM
tpelle tpelle is offline
I made a battery hold-down yesterday (the battery is just a little too high for the original one to work) to replace the temporary bungee cord field-expedient job. I used two 3/16" x 5" galvanized bolts from Home Depot, some hex nuts, a few lock washers and flat washers. The bolts went through the two 1/4" holes in the top of the frame on each side of the battery, held in by a flat washer top and bottom and a single nut and lock washer. I made a strap out of 1" wide aluminum bar with a hole on each end for the bolts, and used a single flat washer, lock washer, and hex nut on each side. Works great.
