Hi all, the petcock on my Quietline tank has started leaking. I have already replaced the bushing once, and I think this valve isn't original, as none online look like it. My question is, this one has 3/8" hose barb on it, and all the ones I see for sale are 1/4". My new carburetor came with a small barb too, I think 1/4" but never measured it. What does your 1450/1650 have? The one on it now has a 1/4 turn lever and the ones for sale have a thumbscrew. Also, some have screens and some don't, I want a screen because there isn't much room for a filter. Thanks!
Philip 1450, 1015, and a pile of parts. |
Also, while I am asking about fuel systems, when I was adjusting the fuel screws on the carb I found that I could turn them quite a ways before the engine speed dipped. Particularly the low speed mix, I turned it a turn and a half before I could hear the slightest speed drop. I set them up at 3200 and 1200 rpm using a 4 cyl dwell/tach and multiplying by four. (dwell was right around 32* so I think I got the points close enough.)
Hummm... Both of my QL tanks have the 1/4 turn deal and my 149 has the thumbscrew (steel tank). Maybe a common hardware store replacement? I believe they're both 1/4" too.
Also, I was able to put an inline filter between the petcock and the carb. NAPA sells a steel body unit that worked out just great! That screen in the petcock isn't nearly fine enough for my taste. |
Sounds like some good advice was given.
btw my 1200 has a push pull type shutoff.it is the original one.
I checked the fitting that came with the carb and it was 1/4", so I ordered the petcock from Patton. I was hung up on "is 1/4" enough" and remembered that I used 3/8" on a built 440 many years ago, so for this little guy 1/4 is fine. I did set the timing per the manual and ran the valves, I just eyeballed the dwell since I was already using the meter for a tach. Gas engines, in my memory, like 28-32* so I knew I was at least in the ballpark. It already had 3/8 line on it, and any 3/8 inline filter I can find is too big to fit in the space between the firewall and the carb. It ran since '78 with a screen, so I'll be happy with that.
I have a 1000 that I used since new. I practically grew up on it because I did yard work and maintenance for a neighbor who gave it to me about 10 years ago. Anyway, it has a 90° valve at the base of the tank. The valve has a small red handle and is original to the tractor. From the serial # it was made in August 1977.
My 800 has the push/pull type of cutoff, a 1976 model.
Only thing better than having a Cub Cadet is USING one
also.. I'm a a fuel filter nazi.. If it runs fuel and has a piston, I put a filter on it. If you end up with 1/4" line and change your mind I can probably attempt to take a picture of what I did on mine if you'd like to see it. It's nothing special. |
![]() Bill |
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
| Thread Tools | |
| Display Modes | |
