Okay, it seems a few of us are having charging system issues right now. Can someone please help me figure out this.
My charging system wasn't showing that it was charging. I changed the v/r to another that I had (older and had to switch the batt and gen term. to match so that part is correct). Once I hooked the battery back up it was trying to start with the key in the off position. I'm stumped and although I don't know a lot about this I did check and make sure that it is correctly wired to the v/r. At this point the amp meter is moving back and forth. any help is appreciated. thanks, Joe
livin the cub life ![]() ![]() ![]() ![]() ![]() |
Sounds like the normally open tips inside your voltage regulator may be stuck closed/welded and applying battery volts to s/g instead of from the kys start position which sometimes happens. More than likely if it just started happening after you put the other v/r on
I'm pretty sure a wrong V/R can do the same thing.
Hey! That's the same thing that happened to my 128. The tractor was purchased with the motor not turning over (not even with a pry bar against the lugs on the pto clutch!) After getting the engine loose, the starter would turn the engine over without using the key.
![]() After trying all the electrical components EXCEPT the v/r, I rapped on the v/r with a screwdriver handle a few times and the problem quit. ![]() The system charges the battery fine now without any needle bounce of the type that you described. That may/may not work for you but give it a try. Just don't use a BFH and destroy a possibly good unit. (Is that money I hear breaking?) FFGino. Happy Cubbing!! |
Thread Tools | |
Display Modes | |
