I bought my 129 a couple months ago and have been working on it as much as I can, it has had its fair share of problems (wrecked cylinder from a thrown rod, rats nest of a wiring harness, bad steering, and nasty paint job). I've put in a different motor and wiring harness along with a new solenoid and key switch and amp meter. Yesterday I finally got to hear it run but there is one little problem. I have to keep holding the key switch to the starting position to keep the motor running. If I try to start it like I normally would it will start up but not keep running. I think it may be the key switch. I have all the wires hooked up right so that seems like the most likely thing to go wrong. I just want to know what you guys think about it.
Cub Cadet 102 106 122 124 1250x2 1650 |
I had that problem.. Reverse the wires on the amp meter fixed mine I think... Something simple like that.. Very frustrating.. I spent hours trying to figure it out.
Original, 109, a pair of 122s, 124 with power lift, 124 with creeper, 126, 147, 1050, 1200, two 1250s, 1450 Dual Stick , another 1450, two 1650s, Gannon Earthcavator, Haban sickle bar and a bunch of other things you either pull, push or hang underneath. |
Sounds like it isn't wired correctly..... or you have the incorrect key switch.
Its wired right I bought a service manual off ebay and followed that. I also have the right switch because it along with the wiring harness are from cub.
The only thing left is a BAD Ignition (or key) Switch.
Take a test light and check the system, in a few minuets you will have your answer.
"If I can't fix it, I can screw it up so bad no one else can either" |
Positive side of coil needs to stay positive 12v after start in "run" position. Comes from "ign" terminal of keyswitch.Mr. Badgley is right on the money here, Gotta test it and see what's happening.
Thread Tools | |
Display Modes | |
