Have you ever seen the infomercial about the aluminum rods that you can use a propane torch with and weld up aluminum? Can't remember the exact name of the product. On the infomercial it looks pretty good. I've looked at the material strength of this repair and it looks pretty good.
If a bigger bolt would fit, I'd go with the bigger bolt. If it won't fit , I'd use the repair the holes with aluminum rods and a torch.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
well ican go with a bigger bolt...7/16 shank size its wat i can fit threw the transfer case holes, just gotta drill the trans out.
Brandon CC models: 86, 1650, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1978 1650 Hydrostat w/44" mower & 42" IH push blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
Well guys thanks for the help on the transfer case bolts, i drilled and tapped for bigger bolts which stopped the leaking
Glad you got it fixed!
good deal ..
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
im glad as well...a gallon of fluid a day was getting old fast. if they strip this time im done
Thread Tools | |
Display Modes | |
