Old 11-21-2011, 10:02 AM
Dougs Cubs Dougs Cubs is offline
Default Drawing for 3 point tillier lift pin
I am looking for a drawing or sketch of the 1" diameter pin that goes in the draw bar hole to lift a tiller on a 1450 cub so I canb make one. Length, stop collar location, cotter pin hole location and height adjustment hole / slot location and dimensions.
Thank,
Doug
Old 11-21-2011, 06:17 PM
bocephus1991's Avatar
Is this what your looking for?
Brian
Old 11-21-2011, 07:25 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Is this photo in the tec. section? If not it should be. It was posted several times lately.
Clay
Old 11-22-2011, 08:15 AM
mmzullo mmzullo is offline
I posted that picture for some else. That wont work on a tiller. Well it would but too long. The lift point is shorter. I have 1 on the shelve I can measure for you.
Old 11-23-2011, 08:51 AM
I think it is too long and I dont recognize the second hole at the lift end.
Thanks though.
Old 11-23-2011, 08:52 AM
If you could I would appreciate it!
Old 02-12-2012, 09:56 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
question,,,
if the hole is further away in the pin, would the tiller lift higher? ( would be heavier too)
my trailer is a tilt bed , and im afraid the tiller will bottom out before it heads up the trailer.
the plow I can just pull the pin. not worried about that.
if the pin was longer, with 2 holes. then when loading it on the trailer move the chain to the far end hole to lift it higher.
Doug
Original , 100 , 125 , 582
Old 02-12-2012, 10:04 PM
I just looked at some pictures I took last year when I used my tiller
click
I used the end hole with no known problems.
Old 04-28-2012, 12:00 AM
machinehead323 machinehead323 is offline
that picture is a good start. from what i have seen is that the original one has a slot in it. im not for sure why though. i would like to get the dimensions for an original one. I also need a tiller depth adjustment knob and the threaded rod that holds the chain. does anyone have dimensions for these?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
