Are there any 1882 owners out there that can tell me if you have to pull the engine to get to the ignition module on this tractor? The metal shroud around the back of the engine is right up against the frame and it doesn't look like there is enough room to pull it out. Thanks for the help.
The engine is going to have to be pulled. You have to take the flywheel shroud off and you just can't do it with it in the tractor.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
