Old 02-24-2011, 07:38 PM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Default 1250 Mystery
My dad was trying to get a 1250 that we acquired running a while back and was having some electrical problems. It kept wanting to ground between the throttle cable and the frame, where the cable runs though a hole in the steering column. When he'd hit the key, sparks would fly. If I remember right, he had the battery cables off and cleaned the ends, had the wires off the starter and cleaned them, and he had the ground cable for the engine off. Part of the time when he hits the key nothing will happen. We have tried different solenoids. Where would be the next good place to start looking for issues? Could bad motor mounts cause any problems? Hour meter? Other??
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 02-24-2011, 11:46 PM
I'd start by looking for a short circuit if it's trying to ground through the control cables.
Old 02-25-2011, 06:23 AM
Simply run a 4GA ground cable from the Motor Block to the Frame.
Old 02-25-2011, 08:12 AM
wj-ihc's Avatar
I'm pretty sure it already has a heavy ground cable from the engine to the frame. I believe it wraps around the front of the engine and bolts around the pivot for the front axle.
Old 02-25-2011, 08:20 AM
I don't understand this...!!
Old 02-25-2011, 09:15 AM
wj-ihc's Avatar
I believe there is a ground cable that bolts to the right side of the engine somewhere around the starter, and it then runs to the right front of the engine and bolts to the support that the front axle is eventually pinned to. If there is not already a wire in this location, then dad must have rigged one up there in an attempt to ground the engine. Hope that clarifies it a bit. lol
