OK, so I've decided the S/G belt on my 149 needs to be replaced. What's the best and easiest way to do this? Do I need to remove the front PTO pulley? Cubs are like boats....if you don't like to tinker with them, you shouldn't own one.
Yep.....The PTO belt has to come off first
but not the pulley
OK, so that sounds fairly easy. Remove the PTO belt and the S/G belt will slip off then too, while the PTO pulley stays put. Yes??
correctomundo.
Sounds like a piece of cake...
Yes, pull the pin out of the front pto adjustable rod and take the rod out of the little lever. Push the front engagement lever forward (might need to remove the grill to gain enough room). Take the pto belt off of the pto. Loosen the starter/generator bolts and push it toward the engine to give slack to the belt. take the belt off and replace then put everything else back together.
Don't try to over tighten the S/G belt as it will cause the bearings in the S/G undue wear.
