Old 12-03-2010, 11:27 AM
dieseldan123's Avatar
Default K301 exhaust port repair
i ran into this issue with my 123 cub when i disassembled it. the threads in the block are badly corroded and some have completely rusted away. i cant get the elbow exhaust pipe to thread back in. what can i do to get this repaired? i dont want to scrap the block since it is original to the tractor but i also want to be able to use the stock and stack style exhausts i have. my local Case IH dealer said there wasnt any way to repair it other than to make it a boat anchor.
Old 12-03-2010, 11:34 AM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
I think you can drill and tap the bosses to the sides of the exhaust outlet and put a flange on the pipe. I may be wrong. Sombody will either correct me or tell you the correct way to fix it.
Old 12-03-2010, 11:38 AM
thats what i was thinking too. but i was informed by the IH guys that there wasnt enough "meat" to retap the outlet. i had also come across an idea on haveing a bushing at the right diameter put in and tapped for the exhaust but that will be more than i can do since i am limited in tools
Old 12-03-2010, 02:21 PM
jbollis's Avatar
jbollis jbollis is offline
I think you are misunderstanding. He is suggesting that you drill and tap the bosses on either side of the exhaust port(hole). Some blocks are already done and this is were a bolt on manifold would mount. You would not be using the threads in the port(hole) at all.
Sold everything but one.
Old 12-03-2010, 03:45 PM
Ok yea i see what you guys mean there is plenty there to drill and tap the bosses. got a little confused there and not sure how i did that to myself. Thank you guys for the help! :biggrin2.gif:
Old 12-03-2010, 04:13 PM
Don't go and drill to deep. You need to find a spec on how deep to drill, or you might have more of a problem than you started with.
