Old 06-03-2025, 10:32 PM
Tomeseno Tomeseno is offline
Default XT1 Enduro Series Intellipower - Not Starting
Hello, my name is Martin, and I'm new to the forum. I will appreciate your help with my current Lawn Tractor/mower problem. This is an XT1 Intellipower LT42. The model No. is 13A6A92SA10 and the Serial No. is 1G17RB10103. The engine label reads "Cub Cadet 547cc OHV INTELLIPOWER". I bought the mower in September 2024 from Tractor Supply, and it has about 20-30 hrs. on it. It doesn't have a gauge, so I don't know exact hours.
The machine was running great until recently when it started, somewhat suddenly, running "roughly" and sputtering, especially at higher RPM, even when the PTO is not engaged. I parked the tractor and turned it off. The next day, I attempted to start it but had no luck. I replaced the fuel filter, and cleaned the air filter. When I removed the fuel filter, the gasoline flowed freely from the tank into my gas container, so I know the line is not plugged. I removed the spark plug to examine it and noted that it had a black, powdery film all over it (carbon?). I cleaned it off and reinstalled it. The sparkplug gap was intact, and the plug was not worn. I also examined the carburetor, and though I don't have much experience with them, I concluded that it looked clean, not gummy or clogged.
All of my efforts had no effect in getting the machine started. The engine has plenty of crank, so I'm confident the battery is fine.
The machine is under manufacturer's warranty, but, unfortunately, there is not a service provider within 100 miles that will have a look at it. I would appreciate any help in understanding what might be going on with this mower and possibly getting it going again.
Best, Martin W
Old 06-04-2025, 08:07 AM
ironman's Avatar
ironman ironman is offline
You could have any number of things causing your problem.
Since it's under warranty, my suggestion is to go that route because you probably will eventually sooner or later.
This video about "Intellipower" will give you and idea of what your up against.
https://www.youtube.com/watch?v=wcGxGExLh7U
Tags
intellipower, rough, sparkplug, starting, xt1
